Can-Doo
RCM&E electric flight columnist Nigel Hawes has been busy. His latest design, Can-Doo, is the pull-out plan with RCM&E's Dec 2013 issue that's in the shops 15 Nov!
Starting with little more than four sheets of balsa, Can-Doo is a 32" span sport canard that's easy and cheap to build.
It requires an inexpensive 200 watt outrunner, 25 amp ESC and 2200 mAh Li-Po battery and uses ailerons and foreplane for control.
Clear that building board!
