Retro R/C air racing is gaining in popularity in some corners of the globe although this new 58″ span Denight Special from Hangar 9 should make the perfect sem-scale sport flyer. Due out in November it follows the companies form in being designed for glow or electric power with the removable top deck providing easy access to the internals and for a convenient battery change.
With a stunning colour scheme and all the usual Hangar 9 attributes, it should do well. You can see more at www.horizonhobby.co.uk
Wingspan – 58.5″
All-up weight – 6.25-7lbs
Engine required – 46-52 two-stroke or 72-82 four-stroke
Motor required – E-flite Power 46 (60-amp ESC, 4S Li-Po)
