It's the 2019 Special Issue!
VOLUME 62 SPECIAL ISSUE
ON THE COVER
RCM&E's 2019 Special Issue is a regular issue that subscribers receive and sold in the usual newsagents.
Trad' building is the theme this year with, as the cover shouts, no less than 7 plans included!
FREE PLANS
  • FIRST STEP
Easy to build and fly, this is the perfect first-time build for all ages.
  • BAMBINO
A rugged little park-fly sportster that employs simple construction techniques.
  • BAMBINA
The compact low-wing take-anywhere aerobat.
  • GAMINE
The last aircraft designed by the late, great Vic Smeed, this 36” (914mm) span vintage sportster suits diesel or electric power.
  • STICKY
A diminutive version of the classic Stick design - quick build, low cost and maximum fun.
  • BITTY
A two-channel glider that’s perfect for the slope or, better still, a piggy-back launch.
  • TADPOLE
A classic from 1965 and possibly your first foray into single-channel!
TUTORIALS
  • BUILDING FROM PLANS PT.1
More designs to his name than anyone else makes Peter Miller the perfect host. First task is to decipher the plan
  • BUILDING FROM PLANS PT.2
Talking tools and materials
  • BUILDING FROM PLANS PT.3
The fine art of balsa bashing
ON THE BENCH…
  • SIMPLE STARTER
A timeless project to get you started
  • CHOICE CUTS
Perfect joints every time
  • ALIVE AND KITTING
The UK’s trad’ kit business is doing just fine if the number of manufacturers is anything to go by
  • CUTTING A COWL
A good cowl maketh the model
  • REVERSING A MOTOR SHAFT
Not all leccy motors are the same
  • RIVETTING STUFF
PVA at the ready!
  • SIMPLE SPANNERING
Peter Miller gets stuck into some basic engine maintenance
  • MAN OF THE CLOTH
Glass clothing is a technique many aren’t brave enough to try so what better time to dispel a few myths
  • BECOMING A CONVERT
Here at RCM&E we’re asked about ‘internal combustion-to-electric power’ conversions more than any other topic. Time for some good advice
  • TISSUE & DOPE
There’s a lot to be said for the good ol’ fashioned covering method and, as Shaun Garrity explains, it’s easier than you think
  • NEW LIGHT ON OLD WINDOWS
A worthy scale model needs good glazing
  • OFF YOUR TROLLEY
How to make a scale steerable tail wheel
  • SHRINK WRAP
Your step-by-step guide to film covering
  • UNDER PRESSURE
An easy way to create your own moulded canopies
  • SHORT FINALS
After 43 years of kit production Chris Foss bares all!
  • SUBSCRIBE
The UK’s biggest and best-selling model flying monthly straight to your door and a FREE gift too!
It's an issue you won't want to miss so be sure to pop along to your newsagent or model shop and pick up your copy for just £5.99. Better still, why not save yourself some money over the long run, grab a gift and get your copy before anyone else by subscribing? Don't forget the Subscriber Extras too! If you would like a single print copy, you can purchase one from www.mags-uk.com.
