Jeti Duplex 2.4GHz radio
The respected Jeti Duplex 2.4GHz system is now available pre-fitted to the Graupner MX-12 and MX-16 transmitters.
Duplex has, until now, only been supplied in the form of plug-in transmitter modules but that's set to change with the introduction of these new dedicated transmitters to which the Duplex system is pre-fitted.
Jeti have taken the opportunity of re-designing the Jeti Box unit connectors for this exercise so, as you can see, the unit now plugs directly into a socket mounted at the top of the transmitter, the connector itself supporting the Jeti Box. The two-line LCD display provides telemetry data from sensor units in the model.
Puffin models have the two systems available and both are complete with an R8 receiver and two telemetry sensors. Check out www.puffinmodels.com for further information and pricing.
