Lacey M10
PAWS FOR THOUGHT
ALL ABOARD
I always start building with the wing, having read somewhere that this gives time for it to cure whilst building the rest of the model. After all it is the most important part and needs to be straight. In truth, this wing is a fairly simple structure, and being only 40 span it can be built in one piece. You'll have to splice the wood to do this, making sure that the joints are equally spaced at the wingtips on each side. Alternatively, if you're cursed with a small building board, like me, you may have to build the wing in two halves and join at the centre with ply braces.
TAIL FEATHERS
FUSELAGE
This is built in two sections. The front is basically from 1/4 sheet and the rear from 1/4 square, to allow for the correct fuselage taper from the rear of the cabin.
Begin by marking out the upper front 1/4 sheet fuselage section (I normally use carbon paper for this job). Once you've cut the wing seating and front cabin areas to shape, pin this to the plan. Now pin the lower 1/4 sheet strip to the plan and add the 1/4 filler between F1 and F2 plus the three 1/4 uprights. When dry, remove the assembly from the plan and repeat.
ENGINE COWLING
RADIO
COVERING & FINISHING
BITS AND PIECES
NUFF SAID!
Wingspan: 40''
Wing area: 450 sq. in.
All-up weight: 3 lb 2oz
Wing loading: 16 oz / sq. ft.
Engine (recd): .25 two-stroke
Engine used: S.C. .25 two-stroke
Propeller used: Bolly 91M2 x 6''
Radio: 4-channel, 5 servos
Control functions: Aileron, elevator, rudder, throttle
Control deflections: Ailerons ±1M4'', elevator ± 1M2'', rudder ± 1''
