The new Multiplex Easy Cub
Just released by Multiplex, this new 55″ span three-channel model is an out-and-out beginners machine. Beautifully made from the companies now customary Elapor foam and supplied with a full hardware pack, decals etc, the Easy Cub is designed for a Himax 2816-1220 brushless outrunner, 30-amp ESCs and a 2S 2100mAh Li-Po battery. Two standard micro servos are required for the rudder elevator.
The ‘inside’ word is that Multiplex have created another ‘classic’ beginners model here so look out for the full review coming up very soon in RCM&E.
  • Name: Easy Cub
  • Manufactured by: Multiplex
  • RRP: around £59.99
  • Wingspan: 59″ (1400mm)
  • Length: 38″ (980mm)
  • Suggested power system: Himax 2816-1220 brushless outrunner with 30-amp ESC and 2S Li-PO battery.
  • All-up weight: 30oz (850g)
  • Article Tags:
