The new WFT 09 radio system from Jamara
Unveiled at Nuremburg earlier this year, this new system from Jamara will shortly be arriving in the UK. It's a 9-channel modular system designed for 35MHz (in the UK) and 2.4GHz. Jamara tell us that the 2.4GHz system is DSM2 based.
The WFT-09 is supplied with both modules and a 9-channel 35MHz PCM receiver along with a 7-channel 2.4GHz receiver, this latter item dispensing with an add-on satelite receiver unit. The transmitter is compatible with Futaba and JR receivers in PPM mode.
The metal-fronted transmitter features a ball-joint 35MHz aerial, quality main sticks and a back-lit LCD screen. The spec' details are as follows -
  • 10 model memories
  • 3 programmable timers
  • PPM or PCM modulation
  • Heli, glider and acro modes
  • Mixers for delta, crow, spoilers etc.
  • 90, 120 and 140-degree swash plate mixing
  • All mixers fully programmable
  • Assignable switches
  • Trainer function
  • Modes 1-4 compatible
    The expected UK RRP will be around £450 for the set.
  • X
