Sea Fury
E-flite will be re-releasing their 37" (935mm) span Sea Fury, first introduced in 2008.
Previously moulded in the more brittle EPS foam, the model is now made using the far more resilient EPO foam or Z-Foam as E-flite call it. We're told it also adopts a slightly revised colour scheme and power system recommendation although the exhaust weathering is the only cosmetic change initially obvious.
Like the original, mechanical retracts are included for which each requires a micro servo although, again also, the model doesn't require flaps. It's for your Park 450 or 480 outrunner, 10×8 prop, 3S 2200mAh Li-Po battery and 30-amp ESC and should be on sale in December with an RRP of £74.99.
RCM&E subscribers can find our review in the digital archive (August 2008 issue).
